Kit Kat and Enterprise wifi
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Does the new kit kat for the google nexus fix the enterprise wifi issue? I still can't connect at the office or gym.
Welcome to the forums!
I'm not sure that it does. Regarding connection, are you given an error or anything that would allow us to help you problem solve the connection issue?
cbrosejr
3
Thanks for the welcome. There's no error message, just seems to look connected but I can't reach anything while on it. Interesting, I have no problem at all where I'm running AT&T's wifi just at the office in the gym where I'm told we run Enterprise wpa2.
Just curious, no one else seems to have this problem?
cbrosejr
3
Just add further information, I spoke to our IT guy and he says we're using Active Directory with RADIUS server to control user access to the wireless and both sir name and password are required to be entered as well as a certificate to be installed. Is is at any further value to the question
thtknt
