1. daye19's Avatar
    Hi,
    I have samasung galaxy core .
    I want to uninstall default application/processes loaded with phone, so that phone may run faster.
    How can i do that.
    as i am new to android world, please explain in detail.
    Thanks
    12-13-2013 08:41 AM
  2. Golfdriver97's Avatar
    Hi,
    How can i do that.
    Thanks
    Welcome to the forums.
    Depending on the app, it can be disabled. Here is how: http://forums.androidcentral.com/amb...able-apps.html
    B. Diddy likes this.
    12-13-2013 09:26 AM
  3. B. Diddy's Avatar
    For preinstalled apps and system apps that you can't uninstall, disabling is the best bet, as described above. The only way to completely uninstall these kinds of apps would be to root your device, but I wouldn't recommend it if you're not an experienced Android user.
    Golfdriver97 likes this.
    12-13-2013 02:29 PM
  1. Help! Can't find email folders in default email client
    By Xertion3 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-03-2015, 03:28 AM
  2. default data settings
    By Jwh1o1 in forum Sprint Galaxy Nexus
    Last Post: 12-30-2013, 10:29 AM
  3. Default sound when placing a call
    By devbo in forum LG G2
    Last Post: 12-13-2013, 10:39 AM
  4. Default Apps Not Sticking. Any solutions?
    By limdoug in forum Moto X
    Last Post: 12-12-2013, 01:09 AM
  5. Replies: 0
    Last Post: 12-11-2013, 02:08 AM
