Galaxy S4 GPE - noob questions
rob damiani
286
So my new S4 GPE arrives in 48 hours and I cannot wait to start tinkering, (currently on iphone 5). I purchased a SanDisk 32GB Extreme microSDHC card as well. How can I use the SanDisk card? Can I install apps to the card? I assume/hope that I can store pictures/videos/music on the card as well?
What is a launcher?
I'd like to be able to have email, SMS, Calendar, missed call/voicemail notifications directly on my lockscreen as I do now with my iphone. Is this possible? If so, how do I accomplish this?
Thanks.:D
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
What is a launcher?
Thanks.:D
Apps to the SD card are dependant on the developer if they can be moved and how much. Pictures, music, and videos are fine to store on your card. If you are a big shutterbug, I would connect to something like Dropbox and have auto uploading of photos. That way, there is a backup of your pictures.
A launcher is a different User Interface. It is how you interact with the OS. Different launchers can offer more customizing than stock. http://forums.androidcentral.com/ambassador-guides-tips-how-tos/299378-guide-nova-launcher.html
I would highly suggest getting used to the new OS before tinkering with launchers. Give it a week, then put something like Nova on.
At bare minimum, you will have notification icons in the status bar, and the notification shade can be pulled down while in the lock screen. Notifications on the lockscreen are kind of hit and miss, as the last I knew that detail was under litigation.
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
What is a launcher?
Thanks.:D
Yes, you can store pictures/videos and music on the SD card. Golfdriver97 answered everything else :)
rob damiani
286
Great info and advice, thank you. Lockscreen notifications will be a dealbreaker for me.
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
Ok good, thanks for your reply. Is there a setting that I'll need to edit in order to accomplish this?
Only for the pictures and videos. Go to your camera > settings > storage and change it to SD card.
You can load the music onto your SD card if you put it in your PC, might be able to get music from iTunes
rob damiani
286
Musically, I'm all in with Google Play Music. GREAT info on the SD card, thanks again.
- - - Updated - - -
LOL, np, thanks for your time & effort.
Sorry...getting tired, and I missed that part. I am not sure.
akbarramadhani12
