srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Could someone please tell me if the Panasonic RP - HS46E headphones are compatible with a Nexus 5?
Thank you in advance :)
I did some looking around and it looks like those headphones have a 6.5 mm headphone jack and the Nexus 5 supports 3.5 mm jack.
If it has a 3.5 mm jack, then the headphones will work.
Cy3berOdyssey
