1. AntkneeE's Avatar
    I uninstalled an app called Nova Launcher without first backing up my data or restting the default launcher. Yes I am a noob ok. Now I cant get in my Samsung s4 without hard resetting and losing all my data. Is there any hope for me?...well for my phone anyway.
    All positive help would be very very appreciated.
    01-02-2014 05:04 AM
  2. Sizzers's Avatar
    Have you re-started your phone?
    01-02-2014 05:48 AM
  3. AntkneeE's Avatar
    many times. im getting the Complete Action window popup with both Always and Just Once greyed out when I press the Home button. I've actually have my data backed via USB now. system is fine just not able to get past the popup window.
    01-02-2014 06:00 AM
  4. Sizzers's Avatar
    I'm not familiar with the S4 but I would have thought it would have just reverted back to the stock launcher after uninstalling Nova, but obviously not in this case.
    01-02-2014 06:17 AM
  5. B. Diddy's Avatar
    Welcome to Android Central! When you get that Complete Action window, do you have any launcher option to choose? If not, did you disable the stock Launcher when you installed Nova? Go to Settings>Apps (or the App Manager, which is I think how Samsung refers to it), and look for your Disabled apps. Disabled apps are typically listed at the bottom of the "All" list, or have their own category, depending on the Android version. Look for something like "Launcher" or "Homescreen" as a disabled app. If you find it, tap it and tap Enable.
    01-02-2014 11:33 PM
  6. Golfdriver97's Avatar
    Settings>apps>menu>reset app preferences may help too
    From a Sprint Moto X using AC Forums app
    B. Diddy likes this.
    01-03-2014 12:13 AM
  1. cannot renable download manager, help?
    By skaterose in forum Verizon Droid DNA
    Last Post: 08-08-2017, 12:59 AM
  2. How to remove/uninstall samsung by-default application
    By shreyshah05 in forum T-Mobile Samsung Galaxy S4
    Last Post: 08-19-2015, 08:08 AM
  3. Wifi completely disabled after 4.3 patch. HELP!
    By hoodeh in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-03-2014, 02:30 AM
  4. Need Advanced OS/Tablet Help
    By Sebastian Kaine in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-02-2014, 09:36 AM
  5. Multi-window with Nova launcher on the Note 10.1 2014 edition
    By MudBRBque in forum Samsung Galaxy Note 10.1
    Last Post: 01-01-2014, 10:58 PM
