1. YossiD's Avatar
    My Galaxy S2 (Android 4.1.2, phone not rooted) has started turning itself off, even when plugged in and fully charged. To restart the phone I first have to remove and reinsert the battery.
    This has happened to me with several batteries, one aftermarket and one new supposedly OEM (with hologram "ORIGINAL" sticker and s/n).
    Is this a known issue? Virus?
    All help much appreciated.
    01-07-2014 12:50 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Check the battery contacts in the phone, and make sure they're clean. Also worth a system cache partition wipe, in case there's some bad leftover system data that's messing things up. You won't lose any personal data or settings: http://forums.androidcentral.com/sam...2-s3-tab2.html
    Golfdriver97 likes this.
    01-07-2014 12:56 AM
  3. Golfdriver97's Avatar
    Try taking the battery out and spin it on a flat surface. If it spins freely, the battery is bad and needs to be replaced.
    B. Diddy likes this.
    01-07-2014 12:59 AM
  1. Samsung Galaxy Note 10.1 2014 Edition Slow Connection
    By Angel Martinez3 in forum General Help and How To
    Last Post: 04-11-2014, 06:59 AM
  2. S4 wont charge on ac plug only on pc :/
    By An613 in forum Samsung Galaxy S4
    Last Post: 01-08-2014, 09:43 AM
  3. Stuck on htc logo screen
    By khall15 in forum HTC One M7
    Last Post: 01-08-2014, 04:15 AM
  4. Replies: 2
    Last Post: 01-07-2014, 09:55 AM
  5. Replies: 1
    Last Post: 01-06-2014, 09:49 PM
