Hey all,
I've just bought a new android device, the Dell Streak. But I have two problems. First I can't connect to the WiFi in our house. I have Android 1.6, if I press from my home screen on the menu buttons I go to: Settings > Wireless controls > Wi-Fi settings. At this point it is sometimes black for a pretty long time. Now If I toggle Wi-Fi (off and) on again, it starts scanning, but nothing comes up. My mother-in-law has a android smartphone to, and she can see like 2-3 networks which includes our own. Even if I manually add the network, it says "Not in range, remembered". So currently I just use 3G.
Also, I'm unable to track my location in any application. Maybe that works if my Wi-Fi is working too, but it doesn't at the moment. Personally I think its weird that It can't track my location, since I'm connected to one of those antenna's for 3G right? So I would think that at least they could make a rough estimate. And yes, I turned the "Enable GPS satellites" and "Use wireless networks" under "My Location" on.
Does anybody know how to fix this or do you think this is a device problem?
