I have a T-mobile LG G2 and this phone comes with an Infrared (IR) Blaster. The main advertised use is to change the channel on the TV, DVR, Blu-Ray player, etc. but i know LG also allows you to control air conditioners. Well I was wondering if it is possible to program the IR blaster to control devices other than the select few options shown on the stock app. My ceiling fan/light is able to be controlled remotely and i was wondering if there is a way to use my phone to control it instead of the included remote, as i tend to lose it. Seems like this should be within the realm of possibility as LG brags that you can program the IR blaster.
Any recommendations would great thanks!
