Hello All! I just made the switch from an iPhone to the Note 3. I was wondering if there is a way to make the contact stored on my device and the duplicate Facebook contact all into one instead of having two separate ones. Thanks!
Go into your Address Book, select any of the 'duplicate' Contacts, hit the Menu button and select "Link contact" (or tap on the chain icon in the Connection area). There you'll be prompted to select a contact to link or join with the current contact; just select the appropriate duplicate and voil?! Both contacts will now be merged into a single one.
