1. carebearlulu's Avatar
    ok this is what is wrong with the phone. about 2 days ago my phone acted weird it shut off but after a while it came back on. Then yesterday it did the same thing but it never came back on. the phone was fully charged and as i went to reach for my phone to wake it up it didnt do anything. I have tried the power and volume for 2 mins nothing. I have had it on the charger but all it does it is hot but no light. I have never rooted this phone and dont know what is wrong with it. I only had this phone for 1yr and 3 months. All my contacts, recipies, photos, ect are on it i even tried to see if i can contact it to the manager nothing. does anyone know what else can be the problem.
    03-08-2014 01:08 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It's difficult to say, but I'd be concerned that the battery might have failed. Most batteries will last at least a couple of years, but some can be defective or fail early. You may need to bring your phone to a cellphone repair shop.
    03-08-2014 01:25 PM
  3. Rukbat's Avatar
    WHERE is it getting hot when you charge it? As B.Diddy said, if the battery is getting hot it may be time for a new one. Bit if it's getting hot somewhere else, there's something wrong, and it definitely needs repair.
    Whether you can get your data back is iffy, leaning toward "no". Which is why ALL important things should be backed up to at least 2 independent devices.
    B. Diddy likes this.
    03-08-2014 06:14 PM
  4. carebearlulu's Avatar
    i took it into the att service center they couldnt get it up running either they told me to contact asurion insurance and pay a deducable of 200 bucks. ugh..
    03-11-2014 12:34 PM
  5. B. Diddy's Avatar
    The deductible is $200 now? It used to be $99, if I remember correctly.
    03-11-2014 12:40 PM
  6. Rukbat's Avatar
    It depends on the price level of the phone. With the Note 3, AT&T's coverage is $200 ded. Best Buy's coverage is $150. I can remember when it was $50 for a top of the line phone.
    03-11-2014 03:49 PM
  1. Tmobile D801 LG G2 on at&t 3g microcell?!?
    By redeyss in forum T-Mobile LG G2
    Last Post: 06-22-2014, 07:44 PM
  2. Replies: 5
    Last Post: 04-14-2014, 02:48 PM
  3. HTC One: Wi-Fi turns itself on
    By Tim98TA in forum HTC One M7
    Last Post: 03-23-2014, 12:35 PM
  4. My phone says wrong name after "what's up" command...
    By ThatdudeXavi in forum Motorola Droid MAXX
    Last Post: 03-10-2014, 11:08 AM
