Hello everyone. So as the title suggests my nexus 5's battery is draining due to something. I've been using the device for a couple of months now, and it was all fine till one week ago. I used to get a good one day battery timing with about 4 hours of screen time. Now all of a sudden my battery is draining like anything. I believe that it is due to a wakelock as andriodOS and Andriod system, are likely on top of my battery usage. I previously installed GSAM battery monitor pro and under wakelocks, it shows alarm at the top. I have no alarms on, and I have tried deleting my google keep reminders. Still, the battery is draining.
Right now I am having 15% battery remaining after 12h 13m 25s
here are the complete details:
Android OS 72%
Andriod System 8%
Screen 8%
phone idle 3% at 11h 1m 14s
I would really appreciate help as this is making me not being able to use my phone normally. Also the phone keeps hot most of the time. I was also using DS battery saver pro which helped me get the above stats as it drains even more quickly without it.
Any help would be really appreciated.
Nexus 5 Stock Android 4.4.2
Thanks!
Android OS 72%
Andriod System 8%
Screen 8%
Thanks!
