1. outterspacedroid's Avatar
    I just got a new 2014 Chevy Sonic and I have paired my Huawei H881C to the car stereo. Once for "Phone" and once for "Music". Right now I can play the car radio music OR press a button on the car stereo that says "Media" and select "Bluetooth" which turns the car radio music off and lets the GPS voice directions come through the car stereo speakers but no music. I can't have both, the car radio music and GPS voice directions at the same time. Seems like the music volume should mute while the GPS directions are given then return to the previous volume and continue playing the music I had going. Instead it's "either or". Is there a setting I'm missing somewhere?
    05-04-2014 08:26 PM
  2. effreyj's Avatar
    The same exact thing was happening to me. You can download SoundAbout and under "Text-To_Speech behavior" change the "Audio output" to the bluetooth type of your car.
    05-06-2014 04:59 PM
  3. outterspacedroid's Avatar
    Did this work for you?
    05-06-2014 06:35 PM
  4. effreyj's Avatar
    It's not perfect but it works. You have to set a delay or the beginning of the directions get cut off. Also if you are in Bluetooth media mode in your car, the directions get repeated.
    05-07-2014 01:00 PM
  5. Orchid9's Avatar
    Can someone help me? I have a Honda Accord 2013. My smart phone (Samsong S5) works with the bluetooth for calls and text. But not for the GPS on the phone (Maps). It does not work for radio either (radio station I downloaded _ an application on the phone)
    Thanks in advance
    09-29-2014 09:42 PM
  1. Wanted to love the HTC One m8, but too many issues
    By BobR1908 in forum HTC One M8
    Last Post: 01-20-2015, 10:23 AM
  2. How to remove confirmation message when turning mobile data on/ off?
    By Atif_Azim in forum Samsung Galaxy SIII I9300
    Last Post: 05-25-2014, 11:41 AM
  3. How to download attachments
    By dman76 in forum HTC One M8
    Last Post: 05-05-2014, 02:50 PM
  4. How to add applications to multitasking bar?
    By lokistolemrfizzles in forum Samsung Galaxy S5
    Last Post: 05-05-2014, 09:56 AM
  5. Replies: 1
    Last Post: 05-05-2014, 04:17 AM
