Im trying to install non-market .apk files but every time I try, i get ,,there is a problem parsing the package''
Before writing this thread i red lots of other threads with several different solutions.
1. Probably most popular one was to allow instalation of non market apps in settings.
Enabled - doesn't work.
Dissabled, restarted, reenabled - still doesn't work.
2. Solution that helped lots of users - factory reset.
Reseted factory settings several times - doesn't work.
3. Application could be not compatible with my android vesion.
This is what i done:
Downloaded game ,,alchemy'' to my phone from market.
Installed succesfully.
Downloaded same game ,,alchemy'' to SD Card from 5 different sites - doesn't work.
4. Update to newer android version.
So im having Xperia X10 mini pro and the newest version is 2.1 Update 1
The only way to update my phone version is with CyanogenMod.
Downloaded cyanogenMod, tried to install - ,,there is a problem parsing the package''.....
5. Putting .apk files to ,,/'' directory.
Rooted phone.
Downlowded root explorer. (from market)
Copied all .apk files to both ,,/'' and /root directory.
None worked.
6. Using google drive.
Uploaded all files to GDrive from computer.
Downloaded to phone.
So all of these steps CAN help for other users, but didn't helped for me. If there is anything i can try, tell me, i will appreciate it even if it wont work. If noone has any ideas, then atleast tell me if my idea is possible:
Since i rooted my phone and downloaded root explorer, i explored some more phone files and directories. In one of them i found PackageInstaller.apk My question is: can i change the Package installer and hope that it will fix the problem? or its not possible/won't fix.
Thank you anyways
Rooted phone.
None worked.
Thank you anyways
