It has certainly been raining crap on the ol' Suthern_Man for the last month or so.
Now, the first time I try to add some new tunes to my "new" phone, I can't manipulate any data on its SD card via WiFi. I can write, delete, move, rename, anything I want to/from the card from within the phone itself. Just not over WiFi.
I thought it was perhaps the app I was using so I tried another but same thing. The best error code I get is the highly informative "Operation Failed"-Period.
Is there some setting somewhere that holds sway over the ability to write to the SD card? God I hope so. This is really becoming irritating!
Thanks from the bottom of my bruised & battered heart!! :'(
- One half of the motor in our only car decided to self-destruct - Cha-ching! $2800
- Three days after that, my S4 died from a smaller than hairline crack in the display - Cha-ching! $175
- The cat knocked my laptop-the same one on which I had just successfully re-flowed the video chip-off on the floor, breaking, of course!, the screen - ~$50 (when I get around to it)
