I am going to start off by saying that I have rooted my phone using activeroot but all I did with the root aces was disable a few of the annoying at&t things like driving mode.
When I turned my phone on the other day all of the icons on the home screen were squished into a small space at the top of the screen. It looked like the screen resolution was raised but the GUI stayed the same size. I tried a hard reset (after backing up all of my important data) but that did not fix the problem. What is wrong with my phone? Did I just change some setting accidentally or is this a permanent issue? Please help as it is very annoying to use the phone with tiny on-screen buttons everywhere!
*I will add screenshots in a little bit if needed*
