App problem
Ruud00
7
I am trying to login to the The Sun Mobile app however when i click on the password field the app restarts itself over and over.
i have cleared the data and cache and have done a factory reset but still doesnt work.
is there another way to login to the app?
i am using Android version 2.3.6
Kernel version 2.6.35.7-perf+
baseband version a4-03.32.01
And my phone is the Acer liquid metal
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Have you uninstalled/reinstalled? what about check user feedback? Are others have similar issues based on Google Play reviews?
If there is no fix with an uninstall, I would suggest reporting to the developer for a fix and see how that goes.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
Good tips from srkmagnus. It really sounds like a problem with the app, not with your device. Which Sun app is it? Can you show us the link on the Google Play Store?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
Really horrible reviews for that app. I seem to remember someone else having this issue a year ago or so. Not sure if it was ever solved.
kerokekerol
