M marios1441 Well-known member Feb 16, 2014 259 0 0 Visit site Jun 23, 2014 #1 My wifi SSID is not visible anymore. The room is in range.
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,529 4,666 113 Visit site Jun 23, 2014 #2 Welcome to Android Central! Start by rebooting the router. If that doesn't help, make sure your device isn't searching on the wrong band--i.e., if your device can operate on the 2.4 and 5 GHz bands, make sure it isn't set to look for only one band. See other tips here: http://forums.androidcentral.com/am...roubleshooting-wi-fi-connection-problems.html
Rukbat Retired Moderator Feb 12, 2012 44,529 26 0 Visit site Jun 27, 2014 #3 Also make sure that no one disabled SSID broadcast in the router.
