Get marketplace back (no need for factory reset!)
Hello all,
First post here but needed to let those having issues know what worked for me (DROID X recently over the air update to Froyo 2.2, which killed my android market). I will say I am phone newbie and was still able to do this in <15 minutes. I found the fix here:
http://www.google.com/support/forum/p/Android+Market/thread?tid=2d18c1ad06262499&hl=en
I will copy and paste for ease, and all credit goes to tomarppe. IMPORTANT NOTE: make sure to follow the directions, regardless, on clearing old data at the bottom of this step-by-step guide to prevent force quits. Also I needed to POWER PHONE OFF AND THEN BACK ON after clearing data for new downloads and updates to work.
"To get the Market app back, without doing a factory reset. (SAVES ALL DATA AND APPS!!)
Install a file manager like.Estrongs or Astro
To make it less complicated load the Estrongs from here:
http://www.freewarelovers.com/android/download/temp/1284764910_EStrongs_File_Explorer_1.4.5.apk
transfer it with e.g. bluetooth or USB to your phone and install.
After installing the File manager.
1. Go to internal memory root
2. navigate to /system/app
3. Locate Vending.apk
4. push on it to install it
It may force close the first time you run it but the second time it should work
If you still encounter Force Close or download issues. Do the following ( you might want to do it anyway as it is sometimes better to start with a clean slate)
1. Settings -> Applications -> Manage Applications
2. Chose All
3. Find Market
4. Push on it and select Clear data
Now it should work as advertised"
Best of Luck All! Hope you didn't listen to others on Factory Reset!
J. Leupp
