1. AC Question's Avatar
    So far I have tried formatting through my android phone (says card damaged), through Windows UI (can't format), through Disk Management, and through SDFormatter. Nothing has worked. Chkdsk has returned that it is a raw file system and can't be formatted. TestDisk returns that there are no partitions. Any other suggestions of how I can reformat my card back to normal?
    07-14-2014 12:20 AM
  2. jmagid51's Avatar
    It may be damaged. Take it back or return it. Sounds like you have gone through all the steps.
    Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
  3. jmagid51's Avatar
    07-14-2014 12:34 AM
  1. Replies: 3
    Last Post: 07-14-2014, 02:56 AM
  2. Set Alarm Command Not Working CM11
    By mikef1182 in forum Android Wear / Wear OS
    Last Post: 07-13-2014, 11:17 PM
  3. Replies: 1
    Last Post: 07-13-2014, 10:49 PM
  4. When performing factory reset, do you reformat SD card too?
    By U4icLab in forum Samsung Galaxy S5
    Last Post: 07-13-2014, 10:38 PM
