Chocolate cake with fresh cream. Thanks for asking.
And can you download widgets?
And is there an DFU mode in android so if it bricks you can always restore like iphone?
There are some stand alone widgets in Play, but many apps come with them. You can access widgets in one of two ways: Open the app drawer, and there should be a tab at the top that says widgets. Or(on Google Now loaucher), you can long press any open section of the screen and select widgets.
In the custom recovery guide, how to do a Nandroid (backup) is covered. This is always a good thing to do as recovery partitions of the OS are semi-difficult to mess up, and if you have a Nandroid, that can save you from many bad things that can happen when flashing ROMs.
how to access recovery mode?
How to i get a nandroid
do i need to be bricked for it or what?
There's a soft brick that can usually be fixed and then there's a hard brick where you have a fancy paper weight......lolYea bricked is a 100% dead phone right?
That can happen. Rooting can be risky business if you're not careful.I had a skype friend who bricked his htc one m8 he said it cloudn,t even turn on?
If the device is turned off during the flashing process or the wrong files are used. I've used ODIN for many Samsung devices and didn't have an issue because I read everything before I did anything to my phones.Can odin brick it?
