1. Jsreb's Avatar
    My phone froze up so I had to pull the battery. After a few minutes I turned the phone back on and right away a bunch of 'force closes' for all my auto running apps/widgets come up. After closing all those, my widgets don't work at all, and whenever I try to run ANY apps, they force close.
    What happened and what do I do??
    I can't get it replaced because my warranty is already voided from getting it fixed
    11-08-2010 10:58 PM
  2. Kyle Gibb's Avatar
    Interesting, if pulling the battery doesn't (again) work you might have to use the RUU or something to reinstall.
    11-09-2010 12:57 PM
