L Luke Yeldham New member Sep 16, 2014 1 0 0 Visit site Sep 16, 2014 #1 How do I fix a corrupt memory card How do i fix a currupt memory card? Posted via the Android Central App
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,541 4,675 113 Visit site Sep 16, 2014 #2 re: How do I fix a corrupt memory card Welcome to Android Central! Remove the SD card from your device, and then insert it into your Windows PC using a fullsize SD adapter (very cheap to buy if you don't have one: Amazon.com: SanDisk microSD to SD Memory Card Adapter (MICROSD-ADAPTER): Computers & Accessories). Then run chkdsk: http://forums.androidcentral.com/am...guide-using-chkdsk-fix-corrupted-sd-card.html
