1. Cal.Bear.'s Avatar
    I've been using the Motorola Cliq for about 3 months and the battery life fluctuates randomly. I sometimes only have a charge for 10-14 hours while other times I can go 24 hours with heavy use. I updated it and Cell standby uses 43% of battery and Phone Idle uses 38% of battery while display 5%.
    I don't know if I should take the phone back and get a replacement or how to improve this.
    Thank you for your future advice.
    11-11-2010 09:48 PM
