Re: How to uninstall apps?
That action just delete the shortcut for your app. To uninstall an app go to settings > apps > select the app scrolling down > uninstall.
Apps downloaded for you will be in the first tab, for others apps you should swipe to the all tab.
Some apps that come with the phone can't be uninstalled just disabled. The process to do that is the same. Bloatware and Google apps are in this category. Don't get wild disabling, some apps could cause problems in your phone when disabled. If so, enable them back and things will be OK again.
Glad it helped. Ask if you need help with the process or with which apps are safe to disable.
You can also install CCleaner for your phone and use that to uninstall apps. I've been using CCleaner on my PC for a long time and it's always done a great job of cleaning the system and uninstalling programs. It works just as great on the Android system, too.
If you're in the app drawer you can also uninstall apps from there. Long-press on the app and drag it to the uninstall label.
If you have root, you can try uninstall for root.
With that app you can force deleting of apps.
