1. koboltzz's Avatar
    Dear forum members,
    I am trying to build my own cyanogenmod 11 for my smartphone -> LG G2 (Verizon)
    I am able to build from source thanks to many guides. But I need to merge some changes from an author named JackpotClavin on github.
    I managed to clone the repo I need locally in dir named 'TESTcm'.
    So how do I tell 'brunch' command, that he should use for example
    'TESTcm/android_device_lge_vs980' instead of 'device/lge/vs980'
    and
    'TESTcm/proprietary_vendor_lge' instead of 'vendor/lge/vs980/proprietary' ?
    If I use roomservice.xml in local_manifests (and change the corresponding paths), I am not able to repo sync anymore
    Edit: And changes won't get merged
    09-24-2014 05:29 AM
  1. Replies: 2
    Last Post: 09-24-2014, 04:41 PM
  2. HTC 1 issue connecting to PC
    Last Post: 09-24-2014, 11:31 AM
  3. Changing phones - G+ photos
    Last Post: 09-24-2014, 05:17 AM
  4. Converting Image Text to Editable Text
    By cldcp00 in forum Samsung Galaxy Tab
    Last Post: 09-24-2014, 04:26 AM
  5. App to Turn Off Screen ONLY when on home screen
    By chamel30n in forum Ask a Question
    Last Post: 09-24-2014, 02:59 AM
