1. Gil80's Avatar
    Hi. all
    I have froyo 2.2. It seems that the phone is somewhat laggy when I use contacts or simply browse apps or photos. By laggy, I mean stuck for a split second without multi-tasking.
    Do you know anything about this?
    11-12-2010 07:12 PM
  2. igotsanevo4g's Avatar
    Galaxy S phones have not gotten 2.2 from any American carriers. There have been a few froyo leaks, but its use at your own risk. Some get good results some dont.
    Needless to say root is required to install a froyo leak.
    Anyways, try a factory reset. Or use the native built in task killer first, maybe you just got too much stuff running.
    11-13-2010 05:59 PM
  3. thebizz's Avatar
    thank samsung for that rfs format of your internal sd that slows down your phone. hopefully this is the last phone that they add this to because it sucks
    11-13-2010 08:32 PM
  4. Gil80's Avatar
    what's that rfs format?
    The froyo I'm using is official, not leaked version. This is how I got my phone from my carrier.
    11-14-2010 12:03 AM
  5. anon62607's Avatar
    RFS is samsungs relilable file system, intended specifically for dealing with the pecularities of flash devices. It's not a traditional file system and seems to have performance problems that make the whole phone feel abnormally laggy or slow.
    11-14-2010 12:21 AM
  6. Gil80's Avatar
    Thanks for the info.
    11-14-2010 01:38 AM
  7. micbak1's Avatar
    Galaxy Tab is running 2.2 on 3g, doesn't lag at all.
    11-15-2010 01:10 PM
  8. anon62607's Avatar
    Yep. I don't think it uses rfs
    Sent from my SGH-T849 using Tapatalk
    11-15-2010 02:19 PM
