1. Charmed Juan's Avatar
    Did some searching but didn't find an answer to this question.
    I have a stock Droid X, running 2.2
    Can I tether my laptop to the X without rooting or paying $$$$ to verizon?
    With the Tether app, do I need to root?
    11-13-2010 12:34 PM
  2. EvilMonkey's Avatar
    I use Easy Tether which works, but requires a wired/use connection. The free version doesn't allow https sites though but I think its only ten bucks for the full version.
    11-13-2010 04:53 PM
  3. Zorro1's Avatar
    The other is PDAnet, used to be free 30 day trial, easy to set up and use. From June Fabrics. (don't ask me....)
    11-13-2010 05:12 PM
  4. igotsanevo4g's Avatar
    I suggest rooting. That way you have all the tethering you'd ever need.
    11-13-2010 05:50 PM
  5. bclinger#IM's Avatar
    PDANet is what I have used in the past, after the trial period it will no longer connect to secure sites. If you are rooted, Wireless Tethering is a great and stable application.
    11-14-2010 01:35 AM
  6. Charmed Juan's Avatar
    Do you need any software on the PC?
    11-15-2010 12:08 PM
  7. Zorro1's Avatar
    PDAnet gives you a little thingie, technical term, on the PC so that when you connect on your phone, it recognizes the PC.
    11-15-2010 12:54 PM
  8. Kyle Gibb's Avatar
    There are a number of solutions on the Android Market.
    11-15-2010 03:32 PM
