i have a problem with navigation.
model- lenovo s820.
i recently updated my mobile to kitkat but i had a lot of issues with it so i downgraded it back to its base version 4.2.1 from the service center. and now the navigation is not working properly.
when i open the navigation and search for a direction, it loads the route correctly. and the blue arrow(that navigation icon) is also placed in the right place where i am. but as i start moving, the blue navigation icon does not move. it remains constant. what could be the problem.?
i tried reinstalling the maps, made a factory reset too. no use.
any solution?
thank you.
model- lenovo s820.
any solution?
thank you.
