1. DarthLudicrous's Avatar
    I'm curious, I know there are apps that let you create a remote desktop connection from your phone/tablet to your PC, but are there any apps that let your to the opposite; remote into your tablet/phone from your PC?
    09-29-2014 03:16 PM
  2. SpookDroid's Avatar
    I've been told that TeamViewer will let you do that, but I haven't tried it. If you have a newer Samsung Device, you can do that with SideSync 3.
    09-29-2014 04:26 PM
  3. Rukbat's Avatar
    MyPhoneExplorer (donate-ware) will do that, put the phone's screen on your computer screen and give you an input box if there's something you have to enter on the phone. Pressing is a mouse click. Long-pressing is a right mouse click.
    It's not perfect, but it's pretty good considering it's one of the utilities in a program that's really supposed to be used to sync the phone and computer.
    09-30-2014 11:04 AM
  1. What does a triangle with a yellow warning mean on my mobile phone screen?
    By Carole Little1 in forum General Help and How To
    Last Post: 09-29-2014, 07:36 PM
  2. Why isn't my phone sending text messages?
    Last Post: 09-29-2014, 04:38 PM
  3. Can I download a dead phone onto my laptop?
    Last Post: 09-29-2014, 04:34 PM
  4. Replies: 0
    Last Post: 09-29-2014, 02:54 PM
  5. Why is my phone ringing every 15 minutes?
    Last Post: 09-29-2014, 02:51 PM
