1. pdhaudio83's Avatar
    Hi guys.
    Noob.
    I've been rooted for a while, but only flashing .img files, so I'm not too familar. My battery life sucks, I want to get warm 2.2.
    Any help? I rooted using unrevoked... I'm not really sure the steps with this ZIP file. I'd appreciate some help.
    11-15-2010 06:44 PM
  2. pdhaudio83's Avatar
    I tried using nandroid to flash zip using SDCard, but I get error "can't chown/mod /data/sd) (No such file or directory)
    E: failure at line 9:
    set perm 0 0 0777 data:sd
    I have a bit of experience, basically it can't set my permissions (?) but I'm rooted... running sprint lovers ROM
    11-15-2010 06:47 PM
  3. igotsanevo4g's Avatar
    using nand to flash a rom?
    Well I think your lingo is a little twisted but, to eliminate problems an easier way is to download rom manager from the market, and use it to download and automatically flash the rom.
    Make sure you check in the wipe data/cache option.
    If you hit any more snags, post in the thread I got in the evo section. I'll be able to keep track better.
    11-15-2010 07:13 PM
  4. pdhaudio83's Avatar
    didnt realize there was an easy way to download and install ROMs LOL...
    I'll post there.
    here's what I just posted there:
    Igot- I signed up just to PM you and haha- I need 5 posts. I basically JUST got warm installed, after a nice scary dual UID issue. I wiped and figured it out (i hate trial and error)... so I'm good at this moment... recommend addons?
    11-15-2010 07:13 PM
