1. mdebel's Avatar
    any ideas on how to remove a 'favorite' from the phone feature on my Motorola Droid? there doesn't seem to be an edit or delete optiom to enable the removal of unwanted 'favorites' listed
    thanks
    11-16-2010 01:30 PM
  2. mdebel's Avatar
    found the Frequently Called Remover app, so nevermind!
    11-16-2010 01:39 PM
