1. terpitude71's Avatar
    seems like my gmail is only syncing every 6 hours or so, or it does it when i actually open the program. is there a way you can set it to sync more frequently? i checked both the system and gmail settings and couldnt find anything. very frustrating when trying to have an email convo with someone
    12-20-2009 11:56 PM
