1. Android FTW's Avatar
    So, I am going to buy a phone and thinking which one to buy?
    Samsung i5800 or i5700?
    I'm not a techie, don't have much advanced computer knowledge. Can I root spica following a guide carefully? It might be risky.
    On the other hand, 5800 doesn't have good screen resolution, which makes many apps unaccessible to it. My main priority is good web browsing, book reading and of course, apps. My budget is limited, so I don't have many choices. I don't like the SE xperia 10 mini, becuz it's too small.
    What do you suggest guys???
    11-17-2010 09:20 AM
