1. BenjoBrigattaRossa's Avatar
    Ok,guys Im sure that you had this question before,Im sorry but I dont know anything about android,well not anything but....
    So I bought chinese phone to see how they made them,Im very happy with the phone but I want to put a new rom.Everything is ok with this one,I dont have problems,should I change? How to change rom ? WHat I need to do ? As i seen there is not a lot roms for Cubot One ? Can i put some none cubot one rom made for ?
    Basic Information
    Model Cubot One
    Band 2G: GSM 850/900/1800/1900MHz
    3G: WCDMA 850/2100MHz
    Sim Card Dual SIM Card Dual Standby
    Service Provide Unlocked
    Style Bar
    Color Silver,Black
    Shell Material Plastic
    System
    OS Android 4.2
    CPU MTK6589T, Cortex A7 quad core, 1.5GHz; GPU: PowerVR SGX 544
    ROM 8GB
    RAM 1GB
    Screen
    Display Size 4.7 Inch
    Type IPS,capacitive touch screen
    Resolution 1280 x 720 pixels
    Screen Color 16000K Colorsthese are specs.
    Thanks if you help and if you dont thanks again.Sorry for bad english,hope you underastand me
    10-13-2014 01:16 PM
  2. Golfdriver97's Avatar
    Welcome to the forums. The downside to getting phones that are somewhat unpopular, is no one develops for them. You can try looking on CyanogenMod, but I doubt you will find anything.
    Sent from an AOSP M8
    10-13-2014 02:16 PM
  3. BenjoBrigattaRossa's Avatar
    I thought because of procesor.Well than I have to save money to buy some popular.Thanks anyway
    10-13-2014 03:45 PM
  4. Rukbat's Avatar
    To answer your first question, if everything is okay with this phone, and you have no problems with it, you shouldn't put a new ROM on it. The only reason to flash a new ROM is that the new one gives you something you don't get with the stock one (even if it's just more speed), that you want - and the new one doesn't take away anything you need. (Like, some ROMs may not handle the GPS properly, and if you use your phone for navigation, that would be a deal breaker.)
    If you want to change the look, install a different launcher, install different icons, install different wallpaper. The Play Store is full of them, many of them free. (The first thing I do with a new phone is install the free version of Nova launcher. My wallpaper is usually something to do with the next holiday (I haven't put any Halloween wallpaper on yet).
    10-13-2014 04:04 PM
  5. BenjoBrigattaRossa's Avatar
    Thanks ,I wanted to change because of kit kat, but nvm when i inszal a launcher i need to get in and if i press home button send me to clasical launcher,how to he send me on installed
    10-13-2014 05:39 PM
  1. Replies: 6
    Last Post: 10-22-2014, 04:55 AM
  2. Can anyone help me decide which Android phone is best for me?
    By Anojan Sivam in forum General Help and How To
    Last Post: 10-19-2014, 12:50 AM
  3. Can anyone help me decide what phone I should get?
    By Shooter560 in forum Ask a Question
    Last Post: 10-13-2014, 01:12 PM
  4. Replies: 0
    Last Post: 10-13-2014, 01:11 PM
  5. Replies: 1
    Last Post: 10-13-2014, 01:06 PM
