1. Y4kuzi's Avatar
    Hey guys,
    I have posted this question in the Ask a Question section,
    but I was unable to reply there so I will repost it here.
    I recently bought a Samsung Galaxy Core 2.
    To keep it short, my GPS is not accurate. Also my connections (WiFi, mobile data) aren't stable.
    Sometimes they just 'stop working' for a while. I presume they are related.
    GPS is not accurate in both Ingress and Google Maps. On my old phone, the Core 1, it all worked flawlessly.
    Internet stops working at random times, mostly noticable while streaming or downloading.
    Here is some info on my phone;
    Model:
    SM-G355HN
    OS:
    Android 4.4.2
    Baseband:
    G355HNXXU0ANH3
    Kernel:
    3.10.17-2573481 dpi SWDD3002 #2
    Build:
    KOT49H.G355HNXXU0ANH3
    The phone is not rooted. I have never dropped the phone. It's only a few weeks old.
    The only apps I have installed (not counting system apps) are; WhatsApp, Kik and Ingress.
    Is there anything I can do to solve this issue? I save Factory Reset as my last resort.
    Also, I cannot return this device, because it's been unboxed and used.
    Thanks in advance.
    10-14-2014 08:12 AM
  2. srkmagnus's Avatar
    Try going into system settings > location. Make sure that location is turned on and the mode is set to "high accuracy". Reboot the device (not required, but may be helpful) and see if gps is improved. If not, then consider a factory reset - backup data beforehand - and see if it works.
    Let us know how it goes.
    10-14-2014 10:12 AM
  3. Y4kuzi's Avatar
    Location is already set to high accuracy (Location based on GPS, WiFi and mobile data).
    I also tried other settings but no difference.
    I will do factory reset if nothing else works, so I prefer to wait a while in case there is a solution out there.
    10-14-2014 10:23 AM
  4. girishxda22's Avatar
    Is there a way to fix it?
    07-13-2016 12:49 PM
  5. girishxda22's Avatar
    I also own a samsung galaxy core 2..facing the same problem...gps not accurate n not detecting only..it only detects by using mobile data r wifi..
    Did it fix after factory reset?
    07-13-2016 12:52 PM
  1. Replies: 2
    Last Post: 10-15-2014, 05:56 AM
  2. Nexus 7 (2013) LTE Not Connecting to Verizon
    By BruceHAZ in forum Google Nexus 7 Tablet (2013)
    Last Post: 10-14-2014, 07:31 PM
  3. What happened to the sound on my Galaxy S4?
    Last Post: 10-14-2014, 04:36 PM
  4. Replies: 0
    Last Post: 10-14-2014, 05:38 AM
  5. Why isn't my wifi password for my Galaxy Tablet 3 8.0 saving?
    Last Post: 10-14-2014, 03:17 AM
