1. erebormt's Avatar
    Hi all!
    I only have one micro USB port and wish to connect my wired controller to my tablet (Samsung Galaxy Note Pro), and also display to the TV. The only solution I can seem to find is some cheap, suspicious Chinese splitters... is there a better solution?
    Currently, I just hook my controller up with a USB OTG cable, but I'd love to hook it up to the big screen. Also, having a port to charge my tablet would be an added bonus, since it drains the battery. Thanks!
    10-15-2014 02:24 AM
  2. zhelf's Avatar
    your option would be to try to set up a screen cast to the tv using a DLNA connector or a mircast device and try to get it to mirror the output on the tablet. I am not sure how the latency would be in playing a game so you would have to try that for yourself but the easiest way is the splitter method.
    10-15-2014 04:52 AM
  1. Android L and Moto X
    By frankTheMaster in forum Legacy Android & Other OS's
    Last Post: 10-17-2014, 11:26 PM
  2. Note 4 App drawer and front pages
    By shb in forum Samsung Galaxy Note 4
    Last Post: 10-16-2014, 11:19 AM
  3. Want to know how to improve an app.
    By blah2623 in forum Android Apps
    Last Post: 10-14-2014, 10:34 PM
  4. Replies: 1
    Last Post: 10-14-2014, 10:18 PM
