1. Cariboo38's Avatar
    Hi,
    I have Android-x86 4.4-r1 Live CD running on my Desktop PC but it does not scan/recognize my home Wi-Fi network.
    What do I have to do?
    -Juergen
    10-18-2014 10:37 PM
  2. Devhux's Avatar
    It's possible your Wi-Fi adapter isn't being detected. That said, I can't seem to find a list of what adapters are compatible with the Android Live CD, so perhaps someone else more familiar with the Android x86 project may have further ideas.
    10-19-2014 07:04 AM
  3. Cariboo38's Avatar
    My Wi-Fi adapter is TRENDnet TEW-6528RP (router) and TRENDnet TEW649UB (Toggle).
    By The Way:
    Samsung Galaxy S4, running on Android 4.3 (Kernel 3.4.5-2057364) has no problem to recognize
    the TRENDnet Wi-Fi adapter and connect to the Internet.
    10-19-2014 12:46 PM
  4. Rukbat's Avatar
    The PC and S4 don't recognize the router, they recognize the hardware inside themselves. Your S4 recognizes its own wifi radio. What Devhux is saying is that your Android Live installation may not be recognizing the wifi adapter in the PC. In your case, since you're running a USB wifi adapter, you'd need the Linux driver for that adapter - which Trendnet probably never wrote. (Trendnet is cheap, but you'll find that Linux will recognize PCI adapters using the Broadcom chipset in almost all cases - adapters like Linksys or D-Link, which cost considerably more.)
    Cariboo38 likes this.
    10-20-2014 11:10 PM
  5. Cariboo38's Avatar
    Thanks! I got the picture.
    Is there a complete list of WiFi adapters supported by Android Live CD?
    (BTW I run Ubunte Linux on my PC and never had a problem with TRENDnet.
    10-24-2014 01:56 PM
  1. Why is the battery life on my Note 4 low?
    By Marguerite Boone in forum Samsung Galaxy Note 4
    Last Post: 09-27-2016, 05:08 PM
  2. Note 4 what do you lose with a launcher
    By techie5 in forum Samsung Galaxy Note 4
    Last Post: 08-09-2016, 09:51 AM
  3. Note 4 How do I keep my screen from waking up when receiving a text?
    By sheffield712 in forum Samsung Galaxy Note 4
    Last Post: 05-03-2016, 02:01 PM
  4. getting watch to buzz in navigation
    By Kegman in forum Moto 360
    Last Post: 10-20-2014, 09:25 AM
