1. Sasha Danielle's Avatar
    Hi there.
    The screen on my Note 3 has started turning green. It started in one corner and has been spreading for a week. It is not solid green, but a dark green hue--darkest at the point of origin in the bottom left corner. This was possibly triggered by a drop, but I'm not completely sure. The glass is fine. There are no cracks or anything like that. The phone, including touchscreen, is completely functional. The only problem is the green hue. Is this a problem with the digitizer or the screen? I mean, do I need to have the digitizer replaced or just the glass?
    Any help would be fantastic.
    10-19-2014 07:24 AM
  2. Slashyou's Avatar
    Hi there.
    The screen it seems since the glass is just glass.
    10-19-2014 07:27 AM
  3. Sasha Danielle's Avatar
    So I need to get that whole screen assembly replaced then?
    10-19-2014 07:50 AM
  4. Rukbat's Avatar
    You need to get the LCD panel replaced. (The screen has 4 panels - , from inside out, they're an LED panel that produces light, an LCD panel that selectively blocks that light, a touch panel and a glass sheet.)
    Considering the labor in taking off the glass and touchscreen to replace the LCD panel, it would be a lot cheaper to have the entire screen replaced.
    10-20-2014 10:16 PM
  1. gun bros 2 isn't working on my s5 is this hapening to anyone else
    By Onalapo Kaitell in forum Samsung Galaxy S5
    Last Post: 10-20-2014, 10:39 AM
  2. Replies: 2
    Last Post: 10-20-2014, 07:30 AM
  3. Note 4 Caller id on missed calls?
    By Vinceaid1 in forum Samsung Galaxy Note 4
    Last Post: 10-20-2014, 06:57 AM
  4. Replies: 1
    Last Post: 10-19-2014, 10:45 AM
  5. Note 4 show part of text message in lock screen?
    By cinek in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 06:53 AM
