1. razstec's Avatar
    Hi, i just bought an alps 809T, and my system data takes over 18GB why is this? how can i remove it?
    thanks
    10-19-2014 07:50 PM
  2. Golfdriver97's Avatar
    Welcome to the forums. Can you show a screenshot of this, please?
    10-19-2014 09:14 PM
  3. B. Diddy's Avatar
    Are you talking about Data Usage (i.e., over 3G/4G mobile data connection), or Internal Storage usage?
    10-20-2014 12:44 AM
  4. razstec's Avatar
    hi, internal storage. thanks
    10-20-2014 03:06 PM
  5. razstec's Avatar
    10-20-2014 03:53 PM
  6. B. Diddy's Avatar
    That seems like an error. Can you try doing a factory reset?
    10-20-2014 04:06 PM
  7. razstec's Avatar
    made the reset but as soon as i started instling my app it did the same thing
    10-20-2014 07:47 PM
  8. B. Diddy's Avatar
    Sorry, I'm not sure I can help you. I'm not familiar with that brand of device, and the way that menu appears seems pretty unconventional to me. Can you contact the manufacturer?
    10-20-2014 11:42 PM
  1. Sprint Note 4 Simultaneous voice & data
    By sfrsteel in forum Samsung Galaxy Note 4
    Last Post: 04-19-2015, 09:36 PM
  2. turbo voice and data
    By chevyman29 in forum Motorola Droid Turbo
    Last Post: 11-30-2014, 07:40 PM
  3. Replies: 4
    Last Post: 10-20-2014, 05:30 PM
  4. Replies: 3
    Last Post: 10-19-2014, 06:24 AM
  5. Replies: 0
    Last Post: 10-18-2014, 11:56 AM
