Hello all. I'm an Android newbie, coming from iOS. I have an S3. I'd like to be able to delete incoming emails and messages from my lock screen and also see today's calendar events. How can I do this?
Printable View
You could use a third-party app like Widgetlocker that replaces your lockscreen and allows you to add widgets to the lockscreen.
Edit: Also, the stock Android 4.4 lockscreen allows you to add widgets by default, but I'm not sure if the Samsung modified one does.
