1. moonman239's Avatar
    The solution will ultimately depend on what's causing the problem.
    Solution 1:
    Disable NFC - that's been known to cause the problem you might be having on Samsung phones.
    Solution 2:
    Force-quit any applications that respond to your voice in the background - this was the solution for me.
    Solution 3 (should work if the sound sounds like the charging sound):
    Clean your device's microUSB port.
    10-24-2014 11:01 AM
  2. SpookDroid's Avatar
    10-24-2014 11:23 AM
  1. Replies: 10
    Last Post: 10-27-2014, 12:38 PM
  2. Replies: 1
    Last Post: 10-24-2014, 06:15 PM
  3. Replies: 1
    Last Post: 10-24-2014, 03:40 PM
  4. Wearing Moto 360 on inside of wrist
    By C. Scyphers in forum Moto 360
    Last Post: 10-24-2014, 11:44 AM
  5. Replies: 2
    Last Post: 10-24-2014, 08:21 AM
