How to fix play store connection error when there is perfectly fine connection?
lanre fafore
I have a Samsung tab 3 so I there is no automatic date and time I have already force stopped the app and cleared the cache and cleared data I have now reset my device so there is no apps and it still won't connect what should I do :'(:'(:'(
Re: How to fix play store connection error when there is perfectly fine connection
Welcome to Android Central! What kind of error are you getting? Do you have the most recent Google Play Store installed (5.0.31)?
koreycabra
