1. The default way for Android is to hold Volume Down + Power buttons. The screen shots will be saved in the folder /Pictures/Screenshots/ in your phone. You can either copy the screenshot from your phone to your computer, then when you post a message in this forum, click on the "Go Advanced" button below your text box to allow attachment. Or you can use a forum app on your phone, such as Tapatalk, and attach it directly.
I believe with the Note 4 you can also take screenshot by swiping the entire edge of your hand from left to right, this is a Samsung feature.
2. Try this video:
For default Android launcher, you just tap and hold the app icon and drag it on top of another app icon, and it will automatically create a folder from them.
3. Not really. Cache files are temporary files that could make the app load faster (or sometimes slower). It's similar to how web browsers cache webpages so the next time you go to that webpage it doesn't have to re-download the entire page. Sometimes some apps have errors and clearing out their cache or clearing the entire app's data could help solve the issue. I wouldn't worry much about it.
4. Yes. But it isn't efficient all the time because some apps automatically launch themselves or stay in the background (which allow them to a load faster or give your notifications). If there are too many background background app they may take fill up memories slow down the phone. If there are apps that you do not want to use at all, you should Disable them instead, this mean it will not show up in the app drawer and it will never run in the background.
10-27-2014 11:22 AM
