1. IMANUT46's Avatar
    How do I see all of my posts.
    10-27-2014 04:20 PM
  2. VW Maverick's Avatar
    Up near your screen name, there is a box that says "Participated."
    Click there and you will see what you are looking for.
    Mav.
    Golfdriver97 likes this.
    10-27-2014 04:29 PM
  3. Golfdriver97's Avatar
    If you mean for the android central app, I don't think you can. You would either need to sign onto the desktop site, or get the forums app.
    Sent from an AOSP M8
    10-27-2014 04:41 PM
  4. B. Diddy's Avatar
    Actually, in the AC app, while you're in the Forums, tap the top dropdown menu--you can tap Participated Threads there, although you can only see the last 100 threads or so that you participated in.
    10-28-2014 06:44 PM
  1. My Autocorrect is all screwed up!!!
    By Moltres_rider in forum Samsung Galaxy S4
    Last Post: 10-29-2014, 06:59 AM
  2. How do I get my Flash CS6 test APKs to play background music?
    By davenation in forum Legacy Android & Other OS's
    Last Post: 10-27-2014, 04:15 PM
