1. delbridge40's Avatar
    when i connect my htc one to tv through hml connector the picture starts to stick but the sound is fine leaving picture and sound out of sync
    10-29-2014 09:12 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Tell us more details:
    1. Which MHL adapter (or SlimPort, as the case may be)?
    2. Which video app?
    3. Is it a video file you're playing, or streaming video like YouTube?
    It can be any number of issues, but I'd focus first on the MHL adapter--if it's a cheap one, it might not transmit data correctly.
    10-29-2014 11:55 AM
  3. Rukbat's Avatar
    The other possibility is that it's not streaming the video fast enough - the same situation as when you're watching a Youtube video and you see "buffering". That could be due to the video format (larger formats use more data, so they take more time to stream) or the adapter.
    B. Diddy likes this.
    10-29-2014 01:07 PM
  1. Replies: 2
    Last Post: 09-19-2014, 08:44 AM
  2. "USB connector connected" when charging
    By cessperience in forum Samsung Galaxy S4
    Last Post: 08-14-2014, 11:22 AM
  3. USB connector for Tab S
    By Pato Palma in forum Samsung Galaxy Tab S 10.5
    Last Post: 07-24-2014, 11:34 AM
  4. connectors have burnt my wrist
    By Zachary Chambers in forum LG G Watch
    Last Post: 07-22-2014, 10:19 PM
  5. Possible bad USB connector?
    By astrohip in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-29-2014, 09:22 AM
