1. ZupBoi's Avatar
    Woke up to find out that my Galaxy Nexus is rebooting randomly and booting also looping sometimes. Fantastic!
    Did some searches on how to fix the problem, and found two ways:
    1) While the phone is running, go to Settings -> Backup & Restore -> Fabric Reset(Hard Reset).
    Since my phone is rebooting so much, I never get a chance to complete this.
    2) Turn off the phone and enter recovery mode.
    This gives me the very helpful error message "No Command".
    My conclusion is fixing this problem from the phone is not possible. Although my knowledge about smart phones is limited so what do I know.
    Anyway, how do I fix this?
    10-29-2014 02:22 PM
  2. Slashyou's Avatar
    You need to hold vol up and power for 3 secs when in recovery cant remember if its vol down or up though!
    10-29-2014 05:01 PM
  3. ZupBoi's Avatar
    Thanks,found it. I pressed wipe data/hard reset or whatever the title was. I am not sure if the process completed or if my corrupted phone interrupted it.
    Either way, the phone is still looping .
    I guess it will hit the wall soon.
    10-29-2014 07:01 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Are you able to try a new battery?
    10-29-2014 10:03 PM
  5. ZupBoi's Avatar
    Unfortunately no. I don't have access to one. I tried with the charger plugged, if that makes any difference.
    10-30-2014 08:59 AM
  6. B. Diddy's Avatar
    They're pretty cheap, so it might be worth buying one anyway: Amazon.com: OEM Samsung Galaxy Nexus SCH-I515 Standard Battery (1850mAh): Cell Phones & Accessories
    Try getting back to the Recovery Menu, and select Wipe Cache Partition, then Reboot System Now. Also, if you have an SD card inserted, remove it--a corrupt card can cause issues.
    10-30-2014 10:51 AM
  7. ZupBoi's Avatar
    Well, since I wiped data, the commands(Volume Down + Power button for 3 sec) in Recovery Mode stopped working.
    The SD card it built it.
    I will just buy a new one.
    Thanks for all the help though
    10-31-2014 06:37 AM
  8. B. Diddy's Avatar
    Are you sure that's the right button press combo? This support page says it's Vol Up and Vol Down together, then press Power: Perform a hardware factory reset - Galaxy Nexus
    10-31-2014 11:21 AM
  1. Resetting/deleting contacts?
    By charleskoz in forum Samsung Galaxy Note 4
    Last Post: 01-25-2015, 10:01 PM
  2. Samsung Galaxy S4 Not Charging (Grey Battery)
    By AndroidAlien in forum Samsung Galaxy S4 Active
    Last Post: 11-15-2014, 08:31 AM
  3. N7 (2012) Stuck at Recovery Mode factory reset
    By KansasMatthew in forum Google Nexus 7 Tablet (2012)
    Last Post: 11-04-2014, 10:28 AM
  4. 4 Random apps keep showing up Verizon note 4
    By carraser891 in forum Samsung Galaxy Note 4
    Last Post: 10-30-2014, 08:31 AM
  5. Will The Galaxy S4 Active be receiving Android L?
    By dknight1996 in forum Samsung Galaxy S4 Active
    Last Post: 10-29-2014, 02:34 PM
