1. Nagesh Hegde's Avatar
    Hi..I had bought a Sony Xperia T2 a week back and yesterday I had tried to update the software to 4.4.4. ( currently its 4.4.3). I had to update this via PC thru USB ( thats the only option I had ). I started the update and it was about 60% complete and by mistake I had removed the USB cable and I dint realise for sometimes. When I came to know that this has happened , I tried to reconnect the USB and its not reading. I tried all most all basic troubleshooting but in vain. The phone switches on and immediately there is a message on the screen stating "Software updating failed. Please connect the cable try again " but it doesn't read. I wouldn't mind doing a factory reset but thats also not happening.Any expert to help on advanced trouble shooting?
    11-01-2014 12:31 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Uh-oh. Interrupting a system update is not a good thing--it's why they always warn you not to turn the phone off while updating, and to be sure you have enough battery. You may have bricked the phone.
    11-01-2014 01:20 AM
  1. Replies: 28
    Last Post: 11-10-2014, 05:11 PM
  2. Have the Sony Z3V?
    By PFonte4 in forum Sony Xperia Z3v
    Last Post: 11-01-2014, 05:42 PM
  3. Sony xperia m2 problem
    By W St in forum Sony Xperia Series
    Last Post: 10-31-2014, 12:06 PM
  4. Sony xperia m2 problem
    Last Post: 10-31-2014, 12:04 PM
  5. Is the Sony Xperia Z compatible with Wind?
    By skibnik in forum Ask a Question
    Last Post: 10-31-2014, 06:37 AM
