1. Nitesh ranjan's Avatar
    I can not transfer videoes and photoes from internal storage to sd card in my galaxy note 3 neo. I tried all the apps for transferring videoes but no result. I got a notification that my system prevents this process. So how can i move files from internal storage to sd card???
    11-01-2014 02:49 PM
  2. colyn1353's Avatar
    Try My Files. Download it if it is not installed..
    Open My files and tap SD card then create a couple of folders where you want to move the files to. Then go back and open device storage from My Files and find the file(s) tap the 3 dots and then select. Place a check mark next to the file(s) then the 3 dots and tap move then choose SD card. Go to the folder and tap move here..
    11-01-2014 03:06 PM
  1. Are People noticing higher Data Usage with the Note 4?
    By Andy847 in forum Samsung Galaxy Note 4
    Last Post: 03-26-2016, 05:35 PM
  2. Anybody Come from a Moto Razr Maxx or Maxx HD?
    By PowrDroid in forum Samsung Galaxy S5
    Last Post: 11-01-2014, 02:41 PM
  3. Replies: 0
    Last Post: 11-01-2014, 02:38 PM
  4. How do I update my Android on HTC Desire 818w?
    By Vijay Rakkappan in forum Ask a Question
    Last Post: 11-01-2014, 02:15 PM
  5. Why don't my text with multiple pictures send?
    Last Post: 11-01-2014, 02:06 PM
