1. Chase Hicklin's Avatar
    Look at the top of my screen it has double icon
    Attached Thumbnails Does anyone know how to fix a notification bar?-screenshot_2014-11-01-22-27-56.jpg
    11-01-2014 10:44 PM
  2. B. Diddy's Avatar
    Which phone is that? Does that persist after a reboot? It's worth wiping the cache partition, but we need to know which phone it is first.
    11-02-2014 12:12 AM
  3. Chase Hicklin's Avatar
    Note 4
    11-02-2014 12:34 AM
  4. B. Diddy's Avatar
    11-02-2014 01:48 AM
  5. Chase Hicklin's Avatar
    I tried it thanks but it didn't work
    11-02-2014 08:51 AM
  6. Chase Hicklin's Avatar
    any other options to
    Solve this problem
    11-02-2014 08:21 PM
  7. Daze1's Avatar
    Are you running any modules? When did this start happening?
    11-02-2014 08:24 PM
  8. Chase Hicklin's Avatar
    It started happening several days ago sorry I'm new to android I don't know what you mean by modules I did what he said above I wiped the cache and it didn't do anything I restarted the phone several times nothing it does it all the time unless I'm in an app or the Internet browser
    11-02-2014 08:30 PM
  9. B. Diddy's Avatar
    If you don't mind setting your homescreens up again, try clearing the data from TouchWiz. Go to the App Manager, select TouchWiz Home, and Clear Cache/Clear Data. When you go back to the homescreen, it will have reset to the default, so you'll have to arrange everything again--but hopefully, the notification bar won't be glitched out any more.
    11-02-2014 10:21 PM
  10. Chase Hicklin's Avatar
    I fixed It IM an *****
    11-02-2014 10:33 PM
  11. Golfdriver97's Avatar
    What did you do to fix it?
    11-02-2014 11:01 PM
  12. Chase Hicklin's Avatar
    I was an ***** and screen shot a picture for my wallpaper but I didn't zoom in so the icons were not in the picture so it appeared that their were two sets of icons
    B. Diddy likes this.
    11-02-2014 11:32 PM
  13. B. Diddy's Avatar
    LOL, I can see how that could be confusing!
    11-02-2014 11:59 PM
  1. Replies: 3
    Last Post: 11-06-2014, 01:03 PM
  2. How do I unlock my Puk code?
    Last Post: 11-02-2014, 01:32 AM
  3. Why can't my Note 3 send GIFs?
    Last Post: 11-02-2014, 01:14 AM
  4. My Samsung Galaxy S3 is bricked?
    Last Post: 11-01-2014, 10:32 PM
