1. utsav0311's Avatar
    Hi all,
    I am using Samsung Grand Duos and recently I have rooted my device. Now,I tried uninstalling the King User app which in returned uninstalled some very basic default system apps.
    I am not able to access my camera as I can't see the camera app in the app menu.
    Then I am not able to access any of the Google stuffs like Google Search,Calendar,Gmail or even Play store.
    I have tried restoring it to factory settings but still the same problem.
    Please help me to fix this.
    Thanks!!
    Che Polino likes this.
    11-03-2014 04:08 AM
  2. Sakshat's Avatar
    You download Gapps zip file ur phone search it on google and also download stock Samsung camera app u will get it on Google.....
    11-03-2014 04:16 AM
  3. Rukbat's Avatar
    Just FYI (and for anyone else reading this), Factory Restore removes things you added, it doesn't reinstall things you deleted. It's really more "wipe my additions".
    11-04-2014 04:44 PM
  4. shahzaiblaghari's Avatar
    hey I have got the same problem please let me know if you get your problem fixed I am using Qmobile A30....
    11-30-2014 02:21 AM
  5. debjoy bhowal's Avatar
    I recently rooted my device ...so I uninstalled a lot of system apps....then I wanted to reinstall some of them....I went to play store...I was unable to install them again...so I took the app from my friend via xender.( u can download it from other website....for doing that just type the name of the app u want to install in google...find a proper source to download..then install it from a file manager from ur phone) installed it from there...and guess what...it is running just fine..even it is getting updated from play store
    04-04-2016 07:55 AM
  1. Camera Output Filesize
    By adipabeta in forum Photo & Video Lounge
    Last Post: 11-16-2014, 10:08 AM
  2. Replies: 2
    Last Post: 11-08-2014, 02:43 AM
  3. How do I get my Pop3 account to sync on my Nexus 5?
    Last Post: 11-03-2014, 11:56 AM
  4. Replies: 1
    Last Post: 11-03-2014, 04:29 AM
  5. Replies: 1
    Last Post: 11-03-2014, 04:13 AM
